Slot line excitation in ADS Momentum
nagasatishonnet
Newbie level 3
Newbie level 3
momentum slotline port
Can any body please help on how to excite a slot line in ADS Momentum.
Suppose if I have designed a 70 ohm slot line on some suitable dielectric substrate and I want to simulate it in ADS Momentum(to verify its S-parametrs/ Impedance) over a frequency range how should I excite it.
Can I do it by directly connecting port/ should I compulsorily use Microstrip to Slot line Transition.
slotline ads
Thank You kspalla for your kind help. Have ever worked with slot lines in ADS Momentum.
slot momentum example
I remember on CPW with slot filtering method around 5 years ago.
    V
hi
I wondering you guys could help.. I have the some question..
the link /examples/Momentum/Antenna/Slot_dipole_prj does not work
    V
you can use a microstrip as excitation from the other side
you can use microstrip as excitation .. however, some case like wilkinson power divider which two output port share the same ground ref, you may face with error ..
