CMOS
Advanced Member level 3
What will be the side-effect if I charge 12V/7Ah SLA battery through unregulatd power supply which has 0-15V transformer, bridge rectifier and filter capacitor. There is also 10R/5W current limiting resistor in series with the battery.
And finally I have used a cut-off circuit to stop charging when battery voltage reaches 13.8V.
Now my question is will the battery get damaged because my unregulated DC charging voltage is 17V after rectification and filtering?
