No, because it is same physical line so it can't have skew with itself.do we have skew for common clock path ? if no why ? if yes how do we calculate ?
You won't get a job at AMD with that answer.No, because it is same physical line so it can't have skew with itself.
The post is NOT about clock skew but common clock path (CCP) skew. The dashed line below:
why Professor ? why skew will not be included in common clock path ?skew as in clock skew from clock tree implementation: no.
you may have jitter from one clock edge to the next, which is sometimes also accounted under the term "skew".
Delay occurs in any path be it clock or data. Skew term is used to indicate delay difference between multiple paths such as clock paths or data bits path. Clock path from clock pin to launch register will have skew relative to clock path from clock pin to capture register.Could you please more elaborate with this picture ?
the post from kaz1 explains why. skew is a difference of two delays. if the path is the same, the difference is zero. therefore, no skew.why Professor ? why skew will not be included in common clock path ?
That was a fuzzy cloud answer. Reality is different.the post from kaz1 explains why. skew is a difference of two delays. if the path is the same, the difference is zero. therefore, no skew.
these tools are useful for most common IC designs, but I don';t think you'd get a job at AMD if you said the common clock has zero skew.No digital tool doing CTS has any notion of backplane, or wavelength, or trace delays.
You are mixing skew (as digital designers call it) with jitter.
Can you explain how the CCP skew is affected by fanout capacitance and input threshold of each device??
Yet all digital circuits are inherently analog.
--- Updated ---
FWIW This may be of some benefit to others.
Clock Tree Synthesis | Physical Design | VLSI Back-End Adventure
Clock Tree Synthesis is a process which makes sure that the clock gets distributed evenly to all sequential elements in a designwww.vlsi-backend-adventure.com
FYI Jitter is just the short-term deviation from ideal position in repetitive time intervals.
Jitter gets amplified by variations in thresholds in a clock tree buffers with added fanout capacitance, and with ps delays by ground capacitance, which is why insertion delays should be minimized.
--- Updated ---
Does this contradict your assumption that CCP has no skew?
Thankyou for stating the obvious. But the original question is below.Skew Definition
Clock skew is the insertion delay difference between the destination clock path and the source clock path: (1) from their common point in the design; (2) to, respectively, the endpoint and startpoint sequential cell clock pins.
In the equation below:
- Tcj is the delay from the common node to the endpoint clock pin.
- Tci is the delay from the common node to the startpoint clock pin:Tskewi,j = Tcj- Tci
A true statement but fallacious in this context.No, because it is same physical line so it can't have skew with itself.
