BeringCSparky
Newbie level 2
- Joined
- Dec 6, 2013
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Bering Sea, Alaska
- Activity points
- 39
Hello,
First time posting to this forum and not sure I am posting to the correct place so forgive me if I am not.
I am an electrician and just starting to dip my feet into the world of electronics, I learned from the school of hard knocks and have no formal education so I apologize if my question seems elementary.
I was hoping someone could help me choose or narrow down my choice of some RC snubbers for 120 volt A/C coils.
I have a plc digital relay output controlling a relay, holding amperage of the relay coil is 100ma @ 120 volt A/C I was thinking to add a snubber to the coil to help protect (make last longer ) my reed contacts in the plc output.
Also the relay N/O contact is controlling a 120 volt A/C solenoid valve and I was thinking to install a RC snubber on the solenoid valve coil as well to protect ( make last longer ) the contacts of my relay the holding amperage of the solenoid valve coil is 500ma.
I have done much reading on the subject and have spoken to several manufacturers of RC snubbers but am now more confused than ever.
RK Electronics recommended using 220 ohm resistor with 0.47 uf capacitor for both coils.
Red Lion recommended using 47 ohm resistor with 0.1 uf capacitor for both coils.
Canfield Connectors said they only make one type 10 ohm resistor with .005 uf capacitor that they install in there DIN connectors and they use it for all coils no matter what the resistance.
So you see where I am scratching my head, I have looked at many formulas for calculating the values needed but at the moment they seem a bit over my head. Have also read that you can connect an oscilloscope and try different value components until you see which combination dampens the transients best. (Don’t have scope yet)
I need to order something quick for this project and hope to get some useful advice from any electronics guru's on this site.
Thank you in advance for any information and I look forward to browsing this forum often.
BCS
BCS
