JackofallTrades
Newbie level 6
This is a follow up to the question asked here:
https://www.edaboard.com/threads/312697/
An N-MOSFET is switching current to a solenoid. Supply voltage is 24V. The MOSFET is rated to 60V. The solenoid has a resistance of 4ohms, thus giving an actuated current of 6A.
When the MOSFET is shut off, large back-EMF spikes are produced as the solenoids field is collapse. Adding a flyback diode across the solenoid snubs the spikes, but also introduces an unacceptable delay in the solenoid disengaging after the MOSFET is switched off.
It has been suggested a zener diode in the flyback circuit will allow the field to collapse more quickly.
For the zener voltage, to minimize delay, I should pick a value close to my transistor rated voltage - the supply voltage - the forward drop of the normal diode. For this circuit to leave some margin for the MOSFET, let's assume I select a zener voltage of 60-24-1-5 (for safety) = 30V zener diode.
My question then is what current does the zener need rated at? Initially I would think since the actuated current through the solenoid is 6A, the initial off current through the zener is 6A, leading to a hefty 180W dissipated. This seems excessively large. Indeed, I do not even see 180W rated zener diodes at Digikey for purchase.
If indeed the analysis is correct, what are some other ideas for speeding up the field collapse timing?
