Jan 19, 2012 #1 V vishal_sonam Full Member level 3 Joined Jan 19, 2012 Messages 187 Helped 14 Reputation 28 Reaction score 14 Trophy points 1,298 Activity points 2,457 Hello my name sachin and i m new to antenna world. i want to know that can we take square ground plane for rectangle patch.
Jan 19, 2012 #2 E elchiquito Full Member level 5 Joined Jan 13, 2012 Messages 244 Helped 68 Reputation 144 Reaction score 67 Trophy points 1,308 Activity points 2,578 Yes. For sure you can use a square ground plane for a recntagular patch .why not? Regards
Jan 19, 2012 #3 V vishal_sonam Full Member level 3 Joined Jan 19, 2012 Messages 187 Helped 14 Reputation 28 Reaction score 14 Trophy points 1,298 Activity points 2,457 chachitoelflaquito said: Yes. For sure you can use a square ground plane for a recntagular patch .why not? Regards Click to expand... thanks for your reply actually i was working on gain and i have designed a model in which i have used a square shaped ground plane on rectangle patch using ie3d. i m getting the gain of 12.60dbi.
Jan 19, 2012 #4 E elchiquito Full Member level 5 Joined Jan 13, 2012 Messages 244 Helped 68 Reputation 144 Reaction score 67 Trophy points 1,308 Activity points 2,578 ok. a gain of 12.60dBi for one single patch? holy smokes ! are you sure? Regards
Jan 19, 2012 #5 V vishal_sonam Full Member level 3 Joined Jan 19, 2012 Messages 187 Helped 14 Reputation 28 Reaction score 14 Trophy points 1,298 Activity points 2,457 chachitoelflaquito said: ok. a gain of 12.60dBi for one single patch? holy smokes ! are you sure? Regards Click to expand... hahaha no no not for 1 single patch, i got 12.60dBi for stacked patch antenna with airgap.
Jan 19, 2012 #6 E elchiquito Full Member level 5 Joined Jan 13, 2012 Messages 244 Helped 68 Reputation 144 Reaction score 67 Trophy points 1,308 Activity points 2,578 OK.Alrite, so your issue is resolved? isnt it or any further questions. Regards
Jan 19, 2012 #7 V vishal_sonam Full Member level 3 Joined Jan 19, 2012 Messages 187 Helped 14 Reputation 28 Reaction score 14 Trophy points 1,298 Activity points 2,457 yes yes, my issue is resolved. thank you
Jan 19, 2012 #8 E elchiquito Full Member level 5 Joined Jan 13, 2012 Messages 244 Helped 68 Reputation 144 Reaction score 67 Trophy points 1,308 Activity points 2,578 You are welcome.Probably admin will tag this post solved. Regards ChachitoEL
Jan 19, 2012 #9 V vishal_sonam Full Member level 3 Joined Jan 19, 2012 Messages 187 Helped 14 Reputation 28 Reaction score 14 Trophy points 1,298 Activity points 2,457 chachitoelflaquito said: You are welcome.Probably admin will tag this post solved. Regards ChachitoEL Click to expand... ye may be, but i want to keep in contact with you for my further query in future. i want to ask you that on which tool do you work?
