Sinus PWM (sigma-delta) generation questions
Black Jack
Full Member level 4
Full Member level 4
UKRAINE
pwm sinus
How make sinus PWM without separate sinus generator
and separate PWM modulator?
sinus pwm
If you want to make sinus PWM, you can use Direct Digital Synthesis (DDS) technology. You can do it using a microcontroller and software, or hardware.
dds pwm
Look "Electronics-Lab". Circuit Cellar #131, June 2001. The autor uses DDS with an 8051, and two PWM outputs to generate: sinus, triangle, sawtooth and square waveforms.
Regards, svicent
