single power supply opamp for dataconverters
prabhu_psg
Junior Member level 1
Hi
Can anybody help me in designing opamp with single power supply and full swing for designing an DAC
Can anybody help me with swtch design for Data convertor
Thanks
PRabhu
i think you can use two opamps with single power to achieve the full swing. one opamp is used to cancel the DC offset of the reference voltage on the load, so that the output swing could be Vdd-2Vdsat.
Added after 1 minutes:
you can use a mos switch or a complimetary switch for data converter. reference Razavi's Data Converter chapter 2
use a class AB out put as the opamp which the vcm is vdd/2.
and you can use a cap betweent the output and the load.
another cent of mine. i agree with sunking. the capacitance between the output and the load is used to cut out the DC voltage(Vdd/2).
sometimes, the load is too heavy like ~10Ohms, to make the amp stable, the capacitance should have a huge value. in this case, we'd better use two channels to remove the DC from the load rather than using a single channel. thus, each channel could comprise a opamp with a classAB output.
