sakthisudhursun
Newbie level 5
Hello!!!.
Presently I am working in Single phase inverter for my mini project.
I am Using IRG4PH50UD IGBT from IRF and IR2111(Half bridge with fixed dead time) as driver.
The DC Bus to be operated is 460V.
Upto 150V of DC bus the Output voltage is coming close to theoretical value. But after that there is a huge difference of output voltage around 40V from theoretical value.
Presently I am using +15V power supply for IR2111. Gate resistance of 10 ohm.
What could be the fall in voltage when I operate at higher DC bus.
My switching frequency is 4kHz. SPWM is generated with the help of DSP F2812.
Please help me in debugging this.
