sam781
Full Member level 4
I know single phase motor cannot start alone as rotating magnetic flux is not generated with single phase supply. To make rotating magnetic field in stator single phase supply is made like double phase supply with the help of a capacitor and double phase stator winding. Now, I need to know how to calculate the required capacitor value to be used in the motor supply to get higher efficiency?
For example, we can consider a ceiling fan to calculate the value which is readily available induction motor.
