ciaranq
Newbie level 1
Hey,
so my situation is this: Im currently trying to improve the efficiency of a wireless temperature sensor. On the board currently is a voltage regulator that drops the voltage from 7.4V to 3.3V essentially wasting a lot of the batterys power. My plan was to change the configuration of the batteries from series to parallel as to drop the voltage to 3.7V and double the capacity.
The issue with that is that i need a minimum of 4V to power the temperature sensor itself and 3.3V to power the XBee transmitter.
Having had a look online i have found a little device called a Buck-Boost converter which sounds ideal for what i require, a steady output voltage regardless of whether the input is higher or lower. But i can't find a device that allows me to input my 3.7V battery and output BOTH 3.3V and 4V+.
If anyone has better searching skills or knowledge in this area that would be fantastic.
Regards,
Ciarán
Regards,
Ciarán
