Thanks for the reply.
If my device (MCU/CODEC/etc) all operates at 2.8v, is it still worth it to use a buck regulator at 2.8v driven from Li-Cell operating from 4.2v to 3v?
With a constant load of ~100mA, with a buck regulator at 2.8v with 90% efficiency, I would be saving ~15mA at the battery at 3.7v, more at the higher voltages, less at the lower.
I had always thought that buck regulators would be most beneficial when input-output voltage differences are large, I will be quite surprised if 90% efficiency can be achieved with less then .3-.5v between input and output.
Comments?
