sinewave inverter circuit help
zio_nneo
Full Member level 2
Full Member level 2
circuit for pure sine wave inverter
Can anybody help me on designing the inverter that has very pure sine wave at its output. thanx in advance
Dear zio_nneo,
Yes, I can help you. What kind of help do you need?
I want to design the 40W inverter whose output is pure sine wave. Last time I did one but that doesnot produce sine wave. In that I have just generate the square wave that wave had drived the mosfet Thats it. But its output isnot sine wave. I want pure sine wave 220V as available in AC line.
My suggestion is to use PWM technique, are you familiar with some kind of a micro controller, or you want a design with simple analog components like opamp, comparator?
The pwm modulator frequency should be about 20kHz, the output will have a LC filter to filter the carrier (20Khz) frequency out.
Reactions: kola56
    kola56
What is the power source ? How many Volts ? What must be the frequency at output ?
