themaccabee
Full Member level 4
I'm trying to build a 110V,50Hz ,100VA sine wave inverter
using a Boost section which delivers 170V and using this section for an H bridge driven by IR2110 ICs and finally an LC filter to create back the Sine wave.The controller im using is PIC.
My problem is the output LC filter design
i went through the link **broken link removed**
and saw the LC filter depicted there..But i couldnt find the correct method to design the same?
Can somebody help me?
Also when i tried with the similar LC topology im getting a square wave at the output at no load?
Shall i use a dummy load? But the dissipation is very high in that case bringing the efficiency down.
