Sincronize pcb and circuit
veioloko
Member level 1
Member level 1
Brazil
Hello!
I´m new in PCAD 2002
I have some boards that´s alredy done
However i want to update
How can i do this using the netlist generated by the schematic?
Thanks and sorry for my english
There is an term - Engineering Change Orders (ECO). That was made especially for your situation.
For example, you have sinchronized pcb and sch. Then you need to change sch. In this case you need to press in "SCH Editor" Utils->Record ECOs. After all changes are made, you press Utils->Export ECOs. You will write all changes in file. After you go to PCB Editor with loaded .pcb and press Utils->Import ECOs. Now your sch and pcb are sinchronized.
    veioloko
Thank you!
It worked
However for example:
If I forgot to RECORD ECOS
I have a PCB V1.2 for example and schematic V1.2
I want to UPDATE acording to schematic V1.4.
How Can I do this?
