von Moltke
Junior Member level 1
- Joined
- Sep 11, 2012
- Messages
- 18
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Turkey-Ankara
- Activity points
- 1,439
Hello all,
I am creating a simulink model in fixed-steps. All my blocks' outputs are double with one exception (altough I do not know if that is the source of the problem I will state) pre-lookup table.
When I run the Fixed Point Advisor at the check 1.2 Verify update diagram status I get the error:
Failed
Cannot retrieve port data types.
Parameter must be a string.
Model update failed. Parameter must be a string.
When I remove the pre-lookup table the problem is solved.
What is the nature of this problem? How can I solve it with a pre-lookup block existing in the model?
Failed
