fala
Full Member level 5
Hello, I have built a Voltage Booster for OpAmp and I simulated that with spice in Protel DXP 2004 software package. the design is taken from National application note AN-272 120V Swing Booster(**broken link removed**).
what I need is maximum stability of voltage and capability of maintaining very low voltages. for driver stage I have used different push pulls: Bipolars(as original document), bipolar darlingtons and mosfets. all of them complementary npn, pnp(n, p channels in case of mosfets). I used 1uV(1 micro volt) sinusoidal(1KHz) input signal and compared outputs(in absence of any external noise). some transistors definately had smoother outputs than others. I want to know how much these results are accurate ? if I had no noise in real world, would I get these results? can I rely on results of comparisons between different transistors from this software?
thanks.
thanks.
