u_nes
Newbie
Hello,
I am trying to do a simulation using Piccolo tms320f28027pt but i had a problem running any program successfully.
I wrote the bellow code (just to generate a pwm) and i loaded all necessary source/header files from CCS project (see image) into VSM.
And the VSM studio output was: Firmware is already compiled, but when i start the simulation nothing is happened (no pwm, just high impedance pin)!! even when i generate the HEX file using CCS and upload it to proteus, i got the same output.
you can see in the simulation log bellow that EPWM1 is OFF!!?
could someone show me how to fix this problem.
Thanks,
/* Main.c file generated by New Project wizard
* Created: Tue May 14 2019
* Processor: TMS320F28027PT
* Compiler: CodeComposer for Piccolo
#include "DSP28x_Project.h"
// Prototype statements for functions found within this file.
void InitEPwm1Example(void);
// Global variables used in this example
// Configure the period for each timer
#define EPWM1_TIMER_TBPRD 30000 //1Hz
#define EPWM1_CMPA EPWM1_TIMER_TBPRD/2 // 20% duty cycle
void main(void)
// WARNING: Always ensure you call memcpy before running any functions from RAM
// InitSysCtrl includes a call to a RAM based function and without a call to
// memcpy first, the processor will go "into the weeds"
#ifdef _FLASH
memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (size_t)&RamfuncsLoadSize);
#endif
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the f2802x_SysCtrl.c file.
InitSysCtrl();
// Step 2. Initialize GPIO:
// This example function is found in the f2802x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio(); // Skipped for this example
// For this case just init GPIO pins for ePWM1, ePWM2, ePWM3
// These functions are in the f2802x_EPwm.c file
InitEPwm1Gpio();
//SysCtrlRegs.CLKCTL.bit.XTALOSCOFF=0;
// Step 4. Initialize all the Device Peripherals:
// Not required for this example
// For this example, only initialize the ePWM
EALLOW;
SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;
EDIS;
InitEPwm1Example();
EALLOW;
SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;
EDIS;
// Step 6. IDLE loop. Just sit and loop forever (optional):
//select channel 2
//gpio3 2sec period.......... gpio4 4sec period
for (;;){
void InitEPwm1Example()
// Setup TBCLK
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up
EPwm1Regs.TBPRD = EPWM1_TIMER_TBPRD; // Set timer period
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading
EPwm1Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
EPwm1Regs.TBCTR = 0x0000; // Clear counter
EPwm1Regs.TBCTL.bit.HSPCLKDIV = 1; // Clock ratio to SYSCLKOUT
EPwm1Regs.TBCTL.bit.CLKDIV = 0;
// Setup shadow register load on ZERO
EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
// Set Compare values
EPwm1Regs.CMPA.half.CMPA = EPWM1_CMPA; // Set compare A value
// Set actions
EPwm1Regs.AQCTLA.bit.ZRO = AQ_SET; // Set PWM1A on Zero
EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Clear PWM1A on event A, up count
// No more.
Thanks,
