simulation underwater antenna in HFSS
SamiraAmiri
Newbie level 5
Newbie level 5
hello
I want to simulate an underwater antenna in HFSS. does anyone know anything about it?
I want to put antenna in a box and then submerge the box in to water. do I need to consider the box in radiation box? Do I need to have 2 radiation box ( water and Box)?
Not two radiation boxes.
1. An air volume
2. The case material
3. A water filled radiation box
Question is if you want to model wave absorption and dispersion in water, in this case the radiation box size must be probably increased beyond usual size.
1. An air volume
Hello
Thank you very much for your reply.
I want to design an antenna that can exchange WiFi waves from a depth of 10 meters under the sea. In this case, should I also consider wave absorption and dispersion?
If yes, how many times the size of the radiation box should be the volume of the structure?
Depends on the objective of your simulation. To get correct antenna behaviour, the radiation box must at least cover the near field zone. Absorption per meter can be added separately.
To calculate absorption, after running the program, create a page in that desired area and see the result of absorption. is it right?
LaTeX Commands Quick-Menu:
