Simulation tool for mix-mode environment
mouzid
Full Member level 5
Full Member level 5
Hi all,
I designed a digital module at transistor level using an analog platform (AP) . Another module where designed in VHDL using Design Compiler (DC). Now I'm planing to gather the 2 parts and perform the simulation then the physical implementation of the hole system. Please guide me concerning the tools that can do this and what are the entry files to have from DC and the analog platform AN as an entry point.
Thanks.
Analog/Digital issue
You need a mix-mode environment, this is typically where Cadence is strongest.
Are you using any Cadence tools?
    mouzid
Re: Analog/Digital issue
You can also use Mentor IC studio.
    mouzid
Thanks for you both iwpia50s and ieropsaltic,
For transistor level design I use Cadence Virtuoso with eldo. Do you mean that I can use it ? How ?
Thanks for your replies.
