Simulation Problem with PSPICE
sinansabahm
Newbie level 1
Newbie level 1
Hi All,
I am using PSPICE to get the nonlinear Memristor model simulation. A part of the SPICE Model is as follows:
Gxpos 0 x value={stp(-V(x)+lim_max)*stp(V(plus,minus))*((V(Plus,Minus))^q)*f(V(x),I(plus,minus),p)}
Gxneg x 0 value={stp(V(x)-lim_min)*stp(V(minus,plus))*((V(Plus,Minus))^q)*f(V(x),I(plus,minus),p)}
Cx x 0 0.00008 IC=0.15
Raux x 0 0.01T
Gmem plus minus value={(((V(x)^n))*b*sinh(a*V(plus,minus))+c*(exp(g*V(plus,minus))-1))}
.func f(x,i,p)={1-(x-stp(-i))^(2*p)}
But when running ,I get an error "Missing or invalid expression" not recognizing I(plus,minus) ,which is the current of the VCCS Gmem.
So how to solve such problem? Thanks
Pspice does not support directly referencing behavioral devices currents inside other behavioral sources.
You would need to add dummy voltage source (zero volt) in series with Gmem and refer it's current inside Gxpos ,Gxneg.
