siddu1901
My project is Electrical Impedance Tomography using Arduino mega in proteus. I designed the circuit based on a circuit diagram and code provided in GitHub. I ran the simulation and I don't see the LED's blinking. They have grey squares. Another problem is the code provided has 2 LED's but the circuit diagram had 4 LEDs. I don't know if that's the problem. I will provide the the circuit diagram, my proteus circuit, code and link for the GitHub page. Please help me in solving the issue
Circuit diagram:
My proteus circuit(not the complete circuit because it was large and I couldn't capture the whole ckt):
Link to github page:
Circuit diagram:
GitHub - rahul-sb/EIT: Electrical Impedance Tomography (EIT)
Electrical Impedance Tomography (EIT) . Contribute to rahul-sb/EIT development by creating an account on GitHub.
github.com
C++:
#include "stdint.h"
#include "Settings.h"
#include "ReferenceTable.h"
#include "Pins.h"
#include "Data.h"
// Digital pins for LED and Mux
// Note: These are defined as "static const" so that these are stored in flash memory and not RAM.
static const uint8_t LED_PINS[2] = {18,19};
static const uint8_t CONTROL_PINS_MUXES[3][5] = {{12,11,10,9,13}, //Format: {A0,A1,A2,A3,EN}
{46,48,50,52,44}, // {LSB,...,MSB,ENABLE} (of Mux)
{26,28,30,32,34}};
static const uint32_t SERIAL_BAUD_RATE = 2000000;
// Functions (defined in end of file):
void waitForSignal();
void debugSignal(const Pins&);
static Data data;
static ReferenceTable ref_table;
static Pins pins;
static Settings settings;
void setup(){
clearAll(data);
set(ref_table);
set(pins, LED_PINS, CONTROL_PINS_MUXES);
Serial.begin(SERIAL_BAUD_RATE);
// Wait till arduino gets the settings
waitForSignal();
get(settings);
// Turn on the 1st LED to denote that serial connection has been established
turnLedOnOff(pins,0,1);
// Wait for any signal to start collecting data
waitForSignal();
Serial.parseInt();
Serial.read();
void loop(){
// Turn off the 2nd LED to denote the start of data collection
turnLedOnOff(pins,1,0);
// Print start time in milli seconds
uint32_t start_time = millis();
Serial.println(start_time);
switch(settings.sending_order){
case 0:
readVoltage(data, settings, pins, ref_table);
turnLedOnOff(pins,1,1); // Turn on the 2nd LED to denote that the data has been collected
printVoltage(data);
clearVoltage(data);
break;
case 1:
readResistance(data, settings, pins, ref_table);
printResistance(data);
clearResistance(data);
break;
default:
printVoltage(data);
clearAll(data);
// Send all the data before proceeding
Serial.flush();
// Check if any instruction is available else proceed to next iteration
if (Serial.available() > 0){
// Turn off all the muxes to conserver power
turnMuxOnOff(pins,0,0);
turnMuxOnOff(pins,1,0);
turnMuxOnOff(pins,2,0);
debugSignal(pins);
// Turn all muxes back on for next iteration
turnMuxOnOff(pins,0,1);
turnMuxOnOff(pins,1,1);
turnMuxOnOff(pins,2,1);
// Supporting functions:
void waitForSignal(){
while(!Serial.available()){};
void debugSignal(const Pins& pins){
bool proceed_next_iteration = false;
while(!proceed_next_iteration){
int8_t val = Serial.parseInt();
Serial.read();
1 : Resume after pause
-1 : Stop
-2 : Stop because of possible circuit failure
def : Pause
switch(val){
case 1:
proceed_next_iteration = true;
break;
case -1:
turnLedOnOff(pins,0,0);
while(1){}; // Never proceed
break;
case -2:
while(1){ // Blink both led's indefinitely
delay(1000);
delay(1000);
break;
default: // Pause
waitForSignal();
