And by the way,how should i do to take clipping into consideration?
For standard applications that can accept a few percent harmonic distortion, a Bubba oscillator works well without dedicated gain control if the output signal is taken from the last OP buffer output (U1D in your schematic). By adjusting the loop gain to a value slightly above the required minimal value (ideally 4), the clipping in the amplifier stage U1A and respective harmonic distortions will be low.Solution: To avoid clipping a kind of non-linearity must be introduced which automatically reduces the gain for rising amplitudes (two antiparallel diodes, FET control loop,...).
The oscillator doesn't start because the initial transient solution finds a perfect steady state. The most simple way to start the oscillator is to skip the initial transient solution, it's a SPICE option. Otherwise you need to apply a "kick-start" pulse.
