[SOLVED] Simulating with LT Spice
engr_joni_ee
Advanced Member level 3
Hi, I am trying to simulate in LT Spice but I don't know what happen it is not showing the waveform window. It complain with node u1:1. How do I find that node. I don't have that node in my circuit.
First way, to find a node is by using search (Ctrl + F) and enter its label
--- Updated ---
Your circuit has surely an element labelled U1.
Alright, here is my circuit in which I am simulating ADC driver, single ended to differential. The input is 100 mV sine wave frequency 1 KHz the output should be differential around VCM 0.9 V but actually it is not. I am using the ADC driver LTC6409. the circuit is attached. Is there anything missing in the circuit ?
maybe the problem is your model for u1. where did you get that?
The u1 error is no more there. I am now simulating ADC Driver as shown in previous post. The waveform appear but not as expexted. The output should be differencial around VCM which is 0.9 V but it is not.
First step is to correct your negative power supply which is actually feeding +2.5V. You either want to connect the positive terminal of a -2.5V source or the negative terminal of a +2.5V source...
I have corrected the power supplies, and now it has correct output. Thanks for pointing out.
Solution
