simulating Current-controlled current source...
always@smart
Full Member level 4
Full Member level 4
ASIA
Dear All,
I've tried to simulate a current-controlled current source(CCCS) in Hspice. Refer to the diagram, and the syntax for CCCS is:
Fcccs1 Iout gnd Vsen 0.5
Vsen A gnd 0
My question is : Vsen voltage souce should be 0v or 0.5v (1/2 of the 1v), why?
Thanks in advance...
regards,
smart
always@smart said:
Dear All,
Vsen A gnd 0
regards,
smart
First of all, you cannot sense the current at node A, because it is not a current source, the current at that point is depend on the voltage across the resistor.
As we know, current source does not depend on voltage across it. So, from the diagram, it is not a current control current source. This is what i think...
    always@smart
Dear friend,
When you want to sense current thro' any branch in a circuit you
are suppose to add a voltage source with "0v" as an ammeter. This is
fundamental principles of Spice!
So in ur case you need to insert a voltage source of 0v at point A.
ur code will get modified as
R1 vcc A 1k
R2 B gnd 1k
Vsen A B 0v
Hope this helps ...
    always@smart
Dear all,
i have made a complete netlist :
R1 vcc A 1k
R2 A gnd 1k
Vsen A gnd 0v
.print i(fcccs1)
vcc vcc gnd 1
rout vcc iout 1k
.trans 10n 100n
.end
For the above netlist, i got i(vsen)=1mA , (fcccs1)= 500uA. However I thought i(vsen) supposed to be 1/(1k+1k)=500uA? So I think the Vsen (dummy voltage according to spice manual) will effect the circuit current. Right?
I want to design a CCCS which will not effect by the Vsen, how?
regards,
smart
Dear Friend,
Check with the folloeing netlist!!!
You will get what you are looking for!
R1 vcc A 1k
R2 B gnd 1k
Vsen A B 0v
.print i(fcccs1)
vcc vcc gnd 1
rout vcc iout 1k
.trans 10n 100n
.end
Whatever result you are getting are right!!!
the current in ur netlist thro' Vsen is = 1v/1k = 1ma
