Then you need to tell us what you expected..I am not getting the output waveform as expected.
d123, at risk of hijacking the thread, that isn't what an envelope detector does.
The intention is to recover a low frequency amplitude modulation signal from a high frequency carrier signal.
The modulating signal changes the amplitude of the high frequency carrier, for example a 1KHz sine wave modulating a 2.45GHz carrier would make the carrier level rise and fall at a 1KHz rate. An envelope detector recovers the 1KHz when fed with the modulated 2.45GHz signal. The concept of 'envelope' comes from the outline of the carrier shape rather than the shape of individual cycles within it.
The problem with the schematic is just that the diode chosen is not suitable for use at 2.45GHz. The junction capacitance alone is about 50pF which looks to the signal rather like a 1.3 Ohm resistor at those frequencies.
The way it is supposed to work is the diode rectifies the signal and the RC time constant of C1 and R1 recovers the envelope shape. There will always be some residual ripple in the output but careful choice of time constant will let C1 charge and R1 discharge the voltage at a suitable speed that the amplitude of the carrier is closely followed.
The 1N5819 is a power rectifier, a small signal Schottky diode or a dedicated microwave diode would be more suitable. Bear in mind that the frequency is high enough that wiring inductance and stray capacitance become significant factors if it is constructed.
Brian.
The OP is not looking for a rectifier, he is looking for an envelope detector. His 'expected' waveform in post #5 is, in fact, what the output of an envelope detector should look like. It is not supposed to 'faithfully follow the input', it is supposed to charge the cap to the peak amplitude and hold it. You've changed the circuit into something completely different.I'm not very convinced by post #5 'expected output waveform', in my ignorance, my very great ignorance, that looks like a bog-standard power supply rectified and smoothed signal more than an envelope detector. Why do you think a signal that should faithfully follow the input should hold up the output voltage? I'm hoping to learn something about envelopes, that's why I ask.
And, surely for it to have no negative level at the output requires a second diode that is reverse-biased?
