simulate the MDAC in pipeline ADC
iamxo
Full Member level 4
Full Member level 4
Southeast Asia
mdac pipeline
Well, guys, we usually see FFT results to evaluate the SHA performance. Then, how to evaluate the MDAC in pipeline ADC, i mean using simulation. Is there some way like FFT to deal with the MDAC output?
thank you..
mdac pipleline
Hello iamxo,
Yes, you cannot run a Full-scale transient to verify MDAC SNDR, My suggestion is that you can do it in ADC top-level simulation, Just MDAC use circuit, all the others use verilog-a model.
Indeed, you just need to check your settling behavior, FFT results comes from it.
how to simulate pipeline adc
If i can ensure the settling behavior of MDAC, then the fft result should not be bad, right?
