[SOLVED] Simplifying C script for controlling 64 LEDs
anschau
Hello, i am currently trying to make a led matrix. I am running all the leds off of 8 74HC595 shift registers linked together. my problem is that i have 64 leds to control and to set each led high or low i have to do something like this.
PORTA = 0b00000001;
PORTA = 0b00000010;
PORTA = 0b00000100;
that is to set one led to high, and doing that 64 times for one image takes a lot of time. I know there is a simpler way to this. I tried using a function like this.
PIN_HIGH {
PORTA = 0b00000001;
PORTA = 0b00000010;
PORTA = 0b00000100;
but it did not work. I am not sure what i am doing wrong here. Any help would be much appreciated.
Re: simplifying C Script
You can do
for(i=0;i<=7;i++) PORTA = 0b00000001 << i;
Thank you for your suggestion, but is it possible to use a function to do it? because i was looking for something simple. say i have function A and function B. i was hoping i could just do something like ABBBABBBAAAAABBBBABBB etc. to simplify making an entire animation on the matrix.
I don't understand what are you going to do. Maybe you should share schematic. This is example 48X8 dot matrix.
... and C source code.. (moste important part of it)
Sure, your function should look like this:
void PIN_HIGH() {
PORTA = 0b00000001;
PORTA = 0b00000010;
PORTA = 0b00000100;
Okay thank you. That is what i wanted to know, i guess i just left a few things out. thank you for all your help everyone!
If you are not sending or receiving anything I don't see the reason to use a function
You can simply define a macro
#define PIN_HIGH PORTA = 0b00000001; PORTA = 0b00000010; PORTA = 0b00000100;
whenever you write PIN_HIGH it will be the same as writing PORTA = 0b00000001; PORTA = 0b00000010; PORTA = 0b00000100;
Alex
Wow thank you that worked, and it was so much easier than trying to call a function later in the program.
I don't see how using "PIN_HIGH" is "so much easier" than "PIN_HIGH()"..
