The supply voltage is irrelevant, but I want to power the transmitter and the audio amplifier from the same PSU. Obviously making a voltage divider for the audio amplifier using power resistors will cause a lot of heat.The supply voltage is almost irrelevant, use whatever audio amp you have available because the transformer will isolate the audio from the anode circuit anyway. Forget class-C audio! That is, if you want it to be recognized as voice or music. Class-C output will be a worse than half-wave rectified version of the input, distortion will be close to 100%!
You can use Class-C for the RF as it doesn't really matter what wave shape the carrier is as long as you use a good LPF to remove all the harmonics it creates.
Don't forget that for a single supply audio amp driving a transformer you either have to use a bridged output stage or a coupling capacitor.
Brian.
Your thread reminded me of AM radio transmitters I worked with, used to page doctors in a hospital 50 years ago. The power supply voltage for the RF output tube was modulated.
A doctor was paged in Toronto, Canada and a doctor responded in Buffalo, New York, USA pretty far away across Lake Ontario.
I'm a bit worried that you first mentioned anode modulation, then a supply voltage too low for a vacuum tube, then a 'power oscillator'. Which is it? If you are modulating a single stage oscillator you will produce all sorts of unwanted FM effects and you will have to keep the modulation level low. At 100% modulation, the oscillator would have no power so it would be stopping and starting in sympathy with the modulation.
Brian.
Thank you Frank. I just saw the series transistor AM modulator scheme. It was also used to AM modulate some TV hobby transmitters.Transformer modulation means that the RF PA, runs with its own Vcc. Using a series transistor, the RF PA must run with 1/2 Vcc, so the modulation can swing it from Vcc to 0v (almost).
Frank
Because of the problem matching the Rf PA collector impedance to the amplifier, you will need something like a 3:1 AUDIO transformer able to run with DC through its secondary and rated at 10W. You will never find one. Its best to use choke modulation. Connect a LF choke in series with the PA feed and its Vcc, feed your amplifier to the junction via a suitable capacitor. If you feed a current of about 1/40 of the RF PA's current through the primary in the correct phase, it will cancel the flux caused by the PA's DC current, so leading to lower distortion.
Frank
That design looks 'dodgy'. No bias on the third transistor. Poor matching to the PA MOSFET and no DC isolation at the modulation input which has about 24V DC on it!
Are they really using a PC fan as a voltage stabilizer???
How can 0.5W be quoted as the audio input when the impedance can be anything from a direct short to the supply line or ~1K in mid control setting?
Brian.
The modulation is applied to the PA end of the choke. The whole point of putting a small DC current through the primary is to reduce the core saturation.
I think the "5W" audio input in that circuit , should be 5V. There should be some bias around the audio FETs to get them to drop around 1/2 Vcc.
Frank
The problem with AM is you need to control the supply voltage to control the output power, in other words the RF supply has to follow the audio level. As with audio amplifiers you have positive and negative going 'swings' in the voltage (think of it like the push and pull of a speaker cone) and to represent that as a varying RF level you have to start at half carrier level. That gives it the ability to increase toward full power or decrease toward zero in sympathy with the audio.
With a 'current sinking' modulator such as the LF choke in the supply, you have to pass enough current down the modulator path to be able to drop the supply to about half voltage, it is therefore relatively inefficient. A transformer coupled modulator can decrease and increase the supply voltage so you probably want to run it from 12V so it can potentially go from 24V peak to zero volts. The design with the MOSFETs attempts to do it by using one MOSFET as a controlled current source and the other as a bypass around it. Even if it had capacitive coupling at the input the modulation level would be quite low. It would make more sense to apply the modulation to a single MOSFET, in other words insert the audio at the wiper of the potentiometer and remove the left MOSFET completely. If you try that, bear in mind the audio level will vary with the potentiometer setting and importantly, note that the audio input is at +24V so be careful of the polarity of the coupling capacitor.
Brian.
Brian.
