reik
Junior Member level 3
Hi all, i have currently work on a solar charger circuit which the circuit is shown below.
But kinda not understand is,the zener diode is act like cut off voltage which cut off the charger voltage when the battery is 6.8v which is already full. The concept is when the terminal voltage is full which is 6.8v then the voltage can pass through the zener voltage and cause the transistor open and cause the input voltage to ground.
But..have a question here..the input charging voltage is always higher than 6.8v in order to charge the battery what? wont the charging voltage pass through the zener voltage and make a wrong sense about the battery is already full too?
