Simple USB project for communicating PC and 8051
aamiralikhoja
Member level 5
Member level 5
Hello
Have Any Body Have Simple Project On FDTI USB CHIP AND
8051 MICROCONTROLLER. Which commnicate PC through 8051
Microcontroller. ie I want to trasnfer data from microcontroller and
pc through usb port .Can Any body give me links to some
basic projects to do above tasks. I have no interrest to learn about
boring USB protocol.
simple usb projects
did you see this idea
usb project -stick -linux
Well, First of all, USB is not that boring! it has come from some sort of TELCO world, which is slightly different from computer science camp which makes the entire protocol stack slightly strange. second, if you ever intend to use any of the FTDI chip family (FT232, FT245, FT2232 are the most well known and the most recent) you do not need to know anything about the USB, you just have to connect the chips as stated in the datasheets and application notes, (just 2 capacitors, and 3 resistors are necessary to connect the usb PHY) and you are all done. the FTDI does the rest of the job!
