simple swtiched capacitor circuit using macro op apm model
mahyar
Newbie level 6
Newbie level 6
simple capacitor circuit
Hi
i am trying to simulate a very basic switched capacitor circuit in Virtuoso using a macro op apm model. But when i simulate, as you see in the picture
https://obrazki.elektroda.pl/70_1243607809.jpg
in DC analysis there is very big offset in the output.
and in transient analysis there is an error: no DC convergence
I think my problem is the op amp variables that i have to set up correctly but i don't know if I am right.
my input sin wave has a freq. of 1 KHz
my switches are sampling with f = 4 KHz.
op amp variables:
open loop gain: 10000
GBW: 160 MHZ
negative supply current: 100u
positive supply current: 100 u
out put voltage swing: +- 1.2
nominal supply voltage: 1.2
simple op amp circuits with capacitors
I am not familiar with Virtuoso.
Nevertheless. two comments are to be made:
1.) The circuit cannot work with singel supply as you have no unity gain feedback for dc. That means there is no operating point in the linear region for the opamp .
2.) What do you expect from a dc analysis of a time variant (clocked) circuit ?
simple capacitor circuits
thank you
1- but what should i do to make it works?
2- By the dc analysis I just want to check the output offset at the op-amp that should be reasonable at any time sample.
op apm
mahyar said:
thank you
1.) Use split power supply. That´s normal for S/C circuits.
2.) Of course, dc analysis doesn´t work for sampled data systems. Instead, you must use tran analysis.
advertisements index page/apm models
Even when I use the separate power supplies (+1.2v & -1.2 v) it has the same problem. I understand what you mean and it doesn't really make sense to use DC analysis for the clocked circuits and I do the trans. analysis as well but yet in the DC analysis I shouldn't see the 959V at my output and that's the reason I don't have my proper output in the trans. as well.
Re: simple swtiched capacitor circuit using macro op apm mod
mahyar said:
959V
LvW said:
mahyar said:
959V
so the origine of your 998.5V come from your not inverter input amplifier:
you have: V+=998,5V mybe (V+=998,5mV) and not 998,5V.
