simple shematic ideal diode for 10A 6-30V DC
ovik89
Ideal diode
Hellow! I am looking up power simple shematic ideal diode for 10A 6-30V DC for reverse battery protection, can you help me?
Ideal diode
Where did you get that ideal diode? I want to have one myself :)
Do you have a outside circuit that can controll an relay and that is also not connected to your battery?
Can you afford a normal voltage drop at typical 0,7 volts?
Ideal diode
Hi Proto,
I think you becoms the "Ideal Diode"! In the same shops as ideal women /or ideal mans:)...
K.
The attachement gives you, hopfely, some ideas.
Ideal diode
Yes, but whats your problem with the LTC1357 +FET from my doc-file pls?
it has exactly the spec for your application: up to 48V &10Amper_ you can read it self by LT`s AppliNotes...:)
K.
