Simple Router / Bridge with 8051 derivative?
johan_tr2000
Full Member level 1
Full Member level 1
router 8051
Hi all,
I just wonder that we can design a simple router or even bridge with the 8051 base microcontroller.
May be we can put simple bios and TCP/IP protocol and put the UTP port. We can configure it from the remote PC via TCP/IP.
Any body have design this? pls share.
Thanks + Regards,
JOHAN
microcontroller-interfacing-with-router
Look:
h**p://web51.hw-server.com/setup.html
h**p://web51.hw-server.com/projekty.html
serial
Example application that transfers data from the serial line over TCP/IP. Uses a higher version of the library with compiled serial line, "telnet" client and HTTP server support.
The result is an ETHERNET to RS232 converter, configurable over a WWW interface, with complete TCP/IP implemented - see "Telnet" Setup example.
Reactions: hugore
    hugore
