neazoi
Advanced Member level 6
Hello, I have built a 200mW max @50R HF transmitter (1-30MHz) which has an adjustable output power (1mW-200mW).
From band to band, the output power level changes, so I have to re-adjust the power properly.
I would like to find a way to manually set the output power to 100mW at each band without the need for an oscilloscope each time. The simplest way is a rectifier diode followed by an analogue meter. However these meters are more expensive than my whole circuit, so I would like something that can be done with a LED.
The problem is that I need it to be quite sharp, i.e the led to be switched fully on near 100mW and switched completely off below that.
Can this be done in a simple way? Discrete components is my favourite, if it can be done.
