uncrocks
Newbie level 6
![Newbie level 6](/styles/images/ranks/blevel3.gif)
I'm writing a program for a PIC12HV615 to control the power to a computer and properly shut it down based on inputs from the ignition of a car and a momentary button. I'm writing the code in mBasic. Here's what I have so far:
The GP's are the pins (not sure if that's how I should refer to them?)
I have two questions:
1) In the SLEEP subsection, how do I actually make the chip go to sleep until a change occurs on GP0 or GP5 (I know the chip is capable of this).
2) Is a 300000ms pause too many bits? or do I need to loop through a pause of a shorter length?
Thanks in advance!
Also any other suggestions/code clean-ups are welcome![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
'Raspberry Pi Control
STATE VAR BYTE
STATE = 0
MANOFF VAR BYTE
MANOFF = 0
MANON VAR BYTE
MANON = 0
IGN VAR BYTE
WORKBUT VAR BYTE
WORKBUT = 0
INDEX VAR BYTE
INDEX = 0
TIMER VAR BYTE
TIMER = 0
OUTPUT GP1 'RELAY
RELAY CON GP1
OUTPUT GP2 'SHUTDOWN
SHUTDOWN CON GP2
INPUT GP5 'IGNITION
INPUT GP0 'BUTTON
SLEEP:
'SLEEP UNTIL GP5 OR GP0 GOES HIGH
IGN = GP5
IF IGN = 1 THEN
MANON = 0
GOTO POWERON
ELSE
BUTTON GP0,1,255,0,WORKBUT,1,SLEEPMANUAL
PAUSE 20
ENDIF
GOTO SLEEP
SLEEPMANUAL:
MANON = 1
MANOFF = 0
GOTO POWERON
ONLOOP:
INPUT1 = GP5
IF INPUT1 = 0 AND MANON = 0 THEN
MANOFF = 0
MANON = 0
GOTO POWEROFF
ELSE
GOTO BUTTONCHECK
ENDIF
IF MANON = 1 AND INDEX < 141 THEN 'LOOP THROUGH .1 SECOND DELAY 142 SETS OF 255 TIMES ABOUT 1 HOUR
TIMER = TIMER + 1
IF TIMER = 255 THEN
TIMER=0
INDEX = INDEX + 1
ENDIF
PAUSE 100
ELSE IF INDEX = 142
GOTO POWEROFF
ENDIF
GOTO ONLOOP
BUTTONCHECK:
BUTTON GP0,1,255,0,WORKBUT,1,MANUAL
PAUSE 20
GOTO ONLOOP
POWERON:
HIGH RELAY
LOW SHUTDOWN
STATE = 1
IF MANON = 1 THEN
INDEX = 0
TIMER = 0
ENDIF
GOTO ONLOOP
POWEROFF:
PAUSE 300000 '5 MINUTES
IGN = GP5
IF IGN = 1 THEN GOTO ONLOOP
HIGH SHUTDOWN
PAUSE 120000 '2 MINUTES
LOW RELAY
LOW SHUTDOWN
STATE = 0
INDEX = 0
TIMER = 0
IF MANOFF = 0 THEN
GOTO SLEEP
ELSE
GOTO MANLOOP
ENDIF
MANUAL:
IF STATE = 1 THEN
MANOFF = 1
GOTO POWEROFF
ELSE
MANON = 1
GOTO POWERON
ENDIF
MANLOOP:
IGN = GP5
IF IGN = 1 THEN
PAUSE 20
GOTO MANLOOP
ELSE
GOTO SLEEP
ENDIF
Thanks in advance!
