akbarza
Full Member level 2
hi
I saw a YouTube video that showed a circuit with one transistor that oscillates. unfortunately, I do not access to it.
I plotted schematic of the circuit in ltspice( attached file) as was in that video.
questions:
questions:
- where does the base of the transistor connect?
- Is the position of emitter and collector true or it must be reversed?
- how can I change the circuit to oscillate between 5 and 8 volts, namely these two values are the minimum and maximum amplitude of oscillation.
