Simple NPN transistor issue. Please help.
jwilson
Newbie level 3
Newbie level 3
I am new on here, searched google for an electronic design forum and found this one. I will probably ask a few questions here and there, but mainly will read and learn. I will try to give my advice where it is needed.
I have a simple NPN transistor that I am using as a switch. The original design had a BC857C which drove a 50mA load. The load has now changed to 250mA, therefore I changed the transistor to something more powerful. I chose a MMBT3702. The original design worked fine. The load is another circuit, I cannot see the internals of this load, therefor I take it as a black box for now. The load is a driver for a laser diode module.
On to my problem...
I have the transistor connected as follows:
Base - connected to microcontroller output pin through a 1K resistor. Also have a 100K pullup to 5V
Emitter - connected to 5V
Collector - connected to my load
With no load connected I get 5V on the collector when the transistor is fully saturated. I measure practically 0V for Vce with the transistor saturated and I measure 0.7V for Vbe.
With the load connected I still have 0.7V for Vbe, but I have a voltage for Vce. I now have a 2.3V drop across the collector-emitter of this transistor.
Can someone shed some light for me? I am not the best at analog design. Hope someone on here can help me out. Like I said the original design worked with the smaller load and the BC857C.
Thanks
-John
A transistor works with currents, not voltages. You did not say what is your load current.
With a series base resistor of 1k then the base current from the microcontroller is about 4mA so the load current should not be more than only 40mA.
Using a small PMOSFET, e.g. Si2301/TSM2301 with about 0.1 ohm Rdson would give effectively no voltage drop respectively higher current handling.
    jwilson
If you want to saturate the device (|Vce| < 0.5V) then you
probably need to be at a forced beta of 10 or less. At 250mA
that means you want 25mA or mor out of the uC and through
the limiting resistor. That's not going to play well, I bet. Either
go with a logic level PMOS or go Darlington (if you need the
same logical sense as now) or a NPN first stage and use the
NPN collector current to light the base of the PNP with maybe
a 100 ohm series resistor there to establish ~35mA base
current.
    jwilson
A PIC micro-controller has a max allowed output current of 25mA. when it has a resistor in series with a transistor's base then 150ohms is 27mA.
Thanks for the advice guys. I am going to try a P-channel MOSFET and see if that will help things.
I am stuck to using a single sot23 package component.
Yeah I seen that after I posted. Thanks
