But we can also draw 3 lines parallel to each other,without passing thru the box's centre point..:?:subharpe said:The angles will be 90 degrees because of symmetry. The two blue lines are parallel and of same length. The red line is passing through the centre and therefore is along the radius.
yes u r right if you consider the particular case..yes..subharpe said:You have to consider the symmetry of the structure. As the two blue lines are of same length they must be at same distance from the central line (red). This comes from the symmetry of the structure
Yes you are right..subharpe said:I still persist to say, it is not a special case. The red line has no option but to pass through the centre of the circle as the two ble lines are parallel and of the same length. They can be parallel bit not of the same length if they had not been perpendicular to the diagonal.
