Simple IF loop question
cloudz88
Member level 1
Member level 1
if i use If loop......and i need to put in 2 condition.....how should i write?
if ( condition 1 & condition 2 ) then
end if;
liddat??
some1 pls help..
yes you can do that way, if u need to execute the command when the 2 condition hold true.
if(cond1 & cond2) then
endif
//// the selection strcuture will execute only if both are true
to make the execution to run when only one of the conditions is true use or operator like
if(cond1 | cond2) then
endif
I think u can do like u stated , but consider the other logic levels on your condition1 and condition2 as well.
the conditional expression for the IF statement will give a TRUE/FALSE notion at the end...so whatever you put (even with logical operators), it will be a YES or a NO at the end :D (whether to take the if statements or the else)
