Simple ideas for project with 30 LEDs
dohi
Junior Member level 3
Hi
i have 30 LEDS and i need some idea of sevrel electronic project to use it (simple and brillant light
and another idea
thanks
Re: Simple and LEDs project
What do you have in mind? For indoor decorative purpose ? or for panic light ?
just tell your speciality or the compnents you are planning to use other than your led's
I think of a house project(indoor)
like a matrix of light . With resistors and 9v
Here is a very well done tutorial on LED drivers. I do not know what type of LEDS you will be using, but this tutorial explains a few different driver techniques that you can use. Also, I would look at LED drivers. There are many LED drivers that allow you to vary the brightness, provide PWM signals, as well as even create certain patterns with multiple LEDs.
Here is the link for the LED driver tutorial. Hope it helps...
Regards,
Willis
Reactions: dohi
    dohi
you can also try lighting system by cascading a bunch of decade counters as well they may be helpful
Thanks guys
realy it's help me
