kc9kep
Newbie level 5
Hello!
I'm a newbe at GAL programming.
I'm using a 16v8 gal as a simple I/O address decoder.
I used CUPL to develop the JED file.
The programmed GAL works as anticipated with one hitch ..
Pin 11 (/OE) doesn't control the outputs as I had expected. In other words, the GAL outputs always correctly decode the inputs as expected, regardless of the state of the OE pin-11.
I did not include the /OE pin in my CUPL equations because I assumed (apparently, incorrectly) that the /OE would simply operate similar to a 74ALS244 type IC.
Can someone tell me what I need to do to make the /OE pin operate? (Maybe just include /OE pin-11 in the equations?)
I'm sure the answer is obvious to someone who has done this before
Thanks
Thanks
