luckyvictor
Member level 4
for a BJT/MOSFET in common emitter/source mode,
what is the advantage adding a resistor between E/S and Vss (negative voltage supply)?
and
why the output resistance now is this resistance multiply by the output resistance of the transistor and the transcondutance? e.g Rout = gm*rds*R
Can it be explained without using small signal circuit? just intuitively please?
Many thanks
and
Many thanks
