[SOLVED] Simple code not working
bareil76
Newbie level 6
Newbie level 6
Hi All,
I have a simple code running in a Spartan 6 device. I can flash leds and everything works fine.
I have the following peice of code. Where Tx_mac_wa is always 0
I have verified
1)Clk_SYS is workin
2) Tx_Hwmark_pl is 9
3) Tx_Lwmark_pl is 8
4) Fifo_data_count is 0
always @ (posedge Clk_SYS or posedge Reset)
    if (Reset)
        Tx_mac_wa   <=0;
    else if (Fifo_data_count>=Tx_Hwmark_pl)
        Tx_mac_wa   <=0;								//then...Tx_mac_wa  will  be  asserted  0  to  tell  user  application  to  hold  packet  transmitting./
    else if (Fifo_data_count<=Tx_Lwmark_pl)
        Tx_mac_wa   <=1;
Am I missing something?
Since you didn't list it under things you've verified, what is the Reset doing?
Good point.
The reset is setting everything to 0. Then I verified that Tx_Hwmark = 9 and Tx_Lwmark =8.
    if (Reset)
        begin
        Tx_Hwmark_pl        <=0;
        Tx_Lwmark_pl        <=0;
        end
    else
        begin
        Tx_Hwmark_pl        <=Tx_Hwmark;
        Tx_Lwmark_pl        <=Tx_Lwmark;
        end
The point bking was making is: have you verified reset goes from a 1 to a 0 at some point in time and that you are looking at the *_pl outputs after reset is 0.
Yes I have verified that reset goes from 1 to 0.
If I change Tx_Lwmark to a parameter instead of an input it works!
So the problem was with Tx_Lwmark which could be change in another module by this...
always  @(posedge Reset or posedge Clk)
    if(Reset)
        RegOut      <=RegInit;
    else if (CWR_pulse && !CCSB && CA_reg[7:1] ==CA_reg_set[6:0])    ///Si writeEnable is set AND chipSlect is enabled AND CA_reg[7:1](Addr of external) ==CA_reg_set[6:0] (addr of internal)
        RegOut      <=CD_in_reg;             //update the register value
where CA_reg_set, CA_reg, CCSB and CWR_pulse are all UNCONNECTED signals.
If I change the above to this
    if(Reset)
        RegOut      <=RegInit;
    else
        RegOut		  <=RegInit;
What does that tell me ???? My reset is wrong or RegOut <=CD_in_reg; was evaluated in some way??
Out of context code snippets is not the best way to show us what you've got connected.
Regardless, You state that the following signals are unconnected:
If they are unconnected then everything that uses those signals will be assigned a default value (usually 0) and logic reduction will occur. So in all likely hood the RegOut value was removed or is generating a constant 0.
If you want to synthesize a design you should have all your logic implemented otherwise the tools will remove anything that isn't driven.
