Hello, I have simple circuit shown below, my question is how to find i0 and v0 plus why there are "+" and "-" signs next to 8 Ohm resistor ? Resistors doesn't have polarity, so what it means ?
In the circuit you have an independent current source (the left-most), a current source that generate a current of ampliteude depending from the current flowing in the 2 ohm resistor and two resistors in parallel.
You need to apply Ohm's law, but also Kirchoff's law. The exercise is easy to solve.
If you would like to exercise how to solve electrical circuits probably you will find here some useful examples. I used this examples during my studies and they were helpful.
The + and - symbol is to measure the volatge output. Which will give you the postive volatge level if you reverse the leads while measuring obviously it will give you a negative voltage. You should not connect any loads in a opposite direction.
