simple and not expensive displacement or shock detector
alzomor
Advanced Member level 2
Germany
Shock Detector
Hi
I am designing a battery operated device that should be attached to mother board.
this device should detect if it was de-attached from the mother board.
I am looking for very simple and not expensive displacement detector or shock detector and or any other type of sensors that can do this Job.
Salam
Hossam Alzomor
www()i-g()org
Re: Shock Detector
May be a micro-switch that presses to the motherboard? When your device is removed, the switch will be un-presses. Really cheap.
BTW, here's a good yahoo group dedicated to sensors: **broken link removed**. I'd like to invite you to mirror your question there.
Re: Shock Detector
Hi kender,
Thanks for your advice,
I already thought about this idea bu the Problem is the IP test.
My product should pass IP test so makking any slots for the switch may affect the IP test.
Salam
Hossam Alzomor
www()i-g()org
