BlueMixx
Newbie
I have a SIMCOM A7682E module connected to a Raspberry Pi CM4 via the USB interface.
The connection between the CM4 and SIMCOM works perfectly, and I can communicate (send and receive AT commands) with the SIMCOM via Minicom on ttyUSB1 from the CM4. However, when I disconnect the antenna cable for a few seconds and then try to send AT commands to the SIMCOM, it doesn't work—I can't even type in the Minicom console.
It's almost as if the SIMCOM or the CM4 does not want to allow communication to the SIMCOM. This only happens when the internet disconnects, and after a few seconds, the USB interface freezes.
Any suggestions on how to fix this?
