sim900 ATD*101#; problem
ognjan
Newbie level 5
Newbie level 5
SIM900 can't execute command: ATD*101#;
What is solution ?
can you execute all other basic commands.... and is 101 a valid number in your country
Yes, all other commands work ok.
I make GSM controllers many years...
(> elektronika.rs.ba)
Everything works fine... Siemens mobile phones and Siemens GSM module, even on sim300.
Call *101# is code for check prepaid account, and only this call don’t work with SIM900 modul (return ERROR).
Update firmware SIM900 to 7 version.
And no use ;
ATD*101#
; used voice call only
The command syntax is:
ATD#;
Where "#" is the complete format of the number and, the ";" tells the MODEM that this is "Voice Call" not a "Data Call"
I tried this command many times on different phones and MODEMs.
Hope this helps.
And no use ;
ATD*101#
BUT THIS IS VIOCE CALL!
Answer, of mobile operator is plain text (account and date of expiration of SIM card). Is it the same for most of the Countries?
---------- Post added at 14:21 ---------- Previous post was at 14:19 ----------
Where I can find flash software and flash file ?
Nooooo!!!!
This not VOICE - this CUSD.
Correctly call for SIM900:
AT+CUSD=1,"*111#" // for Kievstar - Ukraine // ( or AT+CUSD=1,"*101#" for UMC )
OK
+CUSD: 0,"Na rahunku: XXX.XXgrn; Xhvyl;Info pro bonusy na *112#,*118# i *119#. Zagubyv svoiu SIM? Vidnovy ii! Info:XXX*XX*",XX
or
ATD*111# // for Kievstar - Ukraine // ( or ATD*101# for UMC )
OK
AT+GSV
SIMCOM_Ltd
SIMCOM_SIM900
Revision:1137B07SIM900M64_ST
check distributor in your region
check distributor in your region[/QUOTE]
I’m find flash software and firmware v.7 file (in attachment), but I’ have a problem in update procedure :(
  • Simcom - sim900 Customer flash loader V1.01.rar
  • 1137B07SIM900M64_ST.rar
Hello all,
i am having the same problem i did try
AT+CSCS="GSM"
OK
please help
Hello got the solution!!!
switch power off until it ask you to switch on the flash untility. Have patients wait a while!
It works any probs ask me!
Ally
After reset module add command at+cusd=1\r" // ---->Enable unstructer service
Hello,
tried
at+cusd=1\r" //
error
Anyway that infernal continous ringing has stopped. Probably sorted out the other bugs too!
2.45 am going to bed
Thanks
Ally
Check the baud rate..
I see it is 460800 ???
Reactions: binu_ji
    binu_ji
i think you load the wrong ver of binary file
you cant use this module agane
[/QUOTE]
Where is attachment ? I cant see it.
dear friend
first select 56k speed
then press start
power up the module and do not free the power key for 10 sec
if do not work
press again start
active reset of module for a moment
Hi ,i need AT coomand for a SIM990A module to auto answer a voice call,can any one help pls,ATSO dosnt seem to work.
thx and regards.
---------- Post added at 10:47 ---------- Previous post was at 10:47 ----------
command* sorry miss spelled.p***
