fanfan69
Newbie
hello, I bought 6 sim7090g modules, the six do not want to start, I specify that I bought them on alixepress from three different suppliers, using PWRKEY nothing happens on the pin we have a voltage of 1.7 volts
There is no "right voltage" for the PWRKEY pin. It must be pulsed to GND for switching the module on/off.thank you for your answers, hello KlausST, the battery is correctly connected the Vbat is a netflag which powers another component on the PCB, hello Aussie Susan, I mean that nothing happens when powering up even with the PWRKEY, the status LED does not light up, the module does not respond to any AT command, I am sure that it is powered because I have the right voltage on the PWRKEY.
I can only repeat. --> use a scope to show the power supply pin voltage.Please check if your power supply is sufficient.
on which pin?on the pin we have a voltage of 1.7 volts
Why only simplified? We need to see the whole story. Show the full schematichere is a simplified diagram of my PCB
These all are theoretical / nominal values. But don´t tell what the SIM module sees.my battery is 2600mah 3.8v and 9.88wh
I don´t know what you call "correctly"the battery is correctly connected
What does "even with the POWERKEY" .. mean?when powering up even with the PWRKEY
