serkam
Newbie level 2
- Joined
- Jul 21, 2018
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- São Paulo - Brazil
- Activity points
- 21
Hi
I am testing SIMCOM 3G SIM5300E that replaced SIM900. There is an Espressif ESP32 communicating with SIM5300E. All communication is OK.
I need to transmit messages to my server using UDP protocol.
The AT sequence I am using follows:
to transmit:
The problem is that nothing arrives at my server in first instance.
I can try several UDP transmissions, all returns "SEND OK", but nothing arrives at server.
But, if I transmit anything from server, manually using the SIM5300E IP (obtained from AT+CIFSR), the message arrives at SIM5300E and, after that, I can send/receive normally at SIM5300E.
The problem is that my server doesn't know the SIM5300E IP at first time, as this IP is dynamically obtained from GSM service. Only when it receives the first message it will know. So, my server can't send the first message to unlock this issue.
Can somebody give me some ideas on how to fix this UDP transmission issue, please?
Thanks in advance.
Sergio
AT+CFUN=4
ATZ
AT+CIPSHUT
AT+CIPMUX=0
AT+CIPMODE=0
AT+CFUN=1
AT+CREG? --> loop until arrives 0,1
AT+CGATT=1
AT+CSTT="myprovider.com"
AT+CIICR
AT+CLPORT="UDP",1100
AT+CIPSRIP=1
AT_CIPHEAD=1
AT+CIFSR
AT+CIPSTART="UDP","myserver",1100 --> wait until arrives "CONNECT OK"
AT+CIPSEND
--> wait for ">"
--> message + 0x1A ( ctrl Z )
--> "SEND OK"
Thanks in advance.
Sergio
